Function to Return a Value - Programming
Sample: A Simple Greatest Common Denominator (GCD) Function (with Euclid Algorithm)
The following sample also exemplifies how it is being used in a simple loop structure.
Without using a user-defined function:
int main() {
  int remainder = 1;
  int a1, b1, a2, b2;
  vexcodeInit();
  a1 = a2 = 20;
  b1 = b2 = 64;
  while(remainder > 0){
    remainder = a1 % b1;
    a1 = b1;
    b1 = remainder;
  Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d", a2, b2, a1);
  a1 = a2 = 60;
  b1 = b2 = 200;
    a1 = b1;
    b1 = remainder;
Using a user-defined function:
int getGCD(int a, int b){
  int remainder = 1;
  while(remainder>0){
    remainder = a % b;
    a = b;
    b = remainder;
  return a;
int main() {
  vexcodeInit();
  Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d",getGCD(20, 64));
  Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d",getGCD(60, 100));
Here shows the sequence of logic flow from the caller function main():
Sample: Average a Set of Numbers
float doAverage(int n1, int n2, int n3){
  float avg = (n1 + n2 + n3)/3;
  return avg;
int main() {
  int n1, n2, n3;
  Brain.Screen.print("average(%d, %d, %d) = %d", 10, 20, 30);
  doAverage(10, 20, 30);
  n1=10; n2=20; n3=40;
  Brain.Screen.print("average(%d, %d, %d) = %d", n1, n2, n3);
  doAverage(n1, n2, n3);
Sample: Enable a Robot to go Forward with Variable Encoders Value
void reportMotionValues(){
  Brain.Screen.printAt(5,100, "%8.2lf%8.2lf%8.2f",
    LeftMotor.position(rev),
    LeftMotor.position(deg));
void goStraight(float totalEnc, float vel){
  LeftMotor.resetPosition();
  LeftMotor.setVelocity(50.0, percent);
LeftMotor.spinToPosition(totalEnc, deg, true); return; } int main() { int enc=1000; // >0: forward, <0: backward vexcodeInit(); for(int i=0; i<10; i++){ enc *= -1; goStraight(enc, 100); Brain.Screen.printAt(5,60, "Done"); reportMotionValues(); //this delay is here only for you to view these actions. //You do not have to put a delay here. wait(2000, msec); } }
As you see, it is close to impossible to enable the robot to go forward and backward at a variable number of times; as it can only be determined at run-time.
