MSI Installers - Install
Installing VEXcode with MSI Installers
Note: If using a remote deployment system such as SCCM you may need to install the Driver Signing Certificate before running the driver installer. The Driver Signing Certificate can be found at this link.
VEXcode Pro V5
1. Install the VS 2013 Redistributable here:
http://download.microsoft.com/download/2/E/6/2E61CFA4-993B-4DD4-91DA-3737CD5CD6E3/vcredist_x86.exe
2. Install the VS 2017 Redistributable here:
https://download.visualstudio.microsoft.com/download/pr/e9e1e87c-5bba-49fa-8bad-e00f0527f9bc/8e641901c2257dda7f0d3fd26541e07a/vc_redist.x86.exe
3. Install VEXcode Pro V5 with the MSI Installer found here:
https://www.vexrobotics.com/vexcode-download
4. Once all three are installed, run:
C:\Program Files (x86)\VEX Robotics\V5Drivers\Console Driver Installer.exe
as an administrator with elevated permissions.
