The “bool” data type generates logically true or false.
Logical/Boolean Operators
Logical/Boolean Expressions
if(<boolean expressions>) { .....<block> }
The <boolean expressions>
will contain a single or complex expression to be evaluated. The <block>
means a block of code that will be executed only if the <boolean expressions>
are evaluated to be true.
More Boolean Expressions:
Boolean Expression | What it means |
if (x == 10) | if x is equal to 10 |
if (x <= 10) | if x is less than and equal to 10 |
if (x > 10 || y > 20) | if x is greater than 10 or y is greater than 20 |
if (x <= 10 && y <= 20) | if x<=10 and y<=20 |
if !(x > 10 || y > 20) | if x<=10 and y<=20 |
if ( !( x <=10 || x >=20) ) | If x>10 and x<20 |
Use special caution when using boolean expressions!
A Boolean type (bool) is a simple integer value.
Let’s take a look at how if (... )
is interpreted:
if (...)
will be computed by the compiler; it produces a meaning of true or false.- Truth is: when ( ... ) produces anything other than 0 (i.e. zero), the
if ( .... )
will mean true. - So: the following expressions are always true:
- if (1)
- if ( 10 )
- if ( anything results non-zero)
Common Errors you must pay attention to:
Example 1:
int X = 10, Y=20; if (X = Y) brain.Screen.print("X and Y are the same.”); else brain.Screen.print("X and Y are different.”);
Output: X and Y are the same.
Why?
if (X = Y)
really means:
- Assign Y to X, so X has value of 20
- The compiler interprets it as if (20) where (20) is true as it is not (0).
Example 2:
int X = 0, Y=0; if (X = Y) brain.Screen.print("X and Y are the same.”); else brain.Screen.print("X and Y are different.”);
Output: X and Y are different.
Why?
if (X = Y)
really means:
- Assign Y to X, so X has value of 0 (zero).
- Compiler interprets it as: (0) as false.
