Configuring a 2-Motor Drivetrain (No Gyro) in VEXcode Pro V5
When starting to program with VEXcode Pro V5, Drive and Turn commands will not appear in the Command Reference until a Drivetrain has been configured.
You can only configure one Drivetrain per project.
If you are configuring a Drivetrain with a Gyro Sensor, click here.
Adding a Drivetrain
VEXcode Pro V5 interface with Robot Configuration button highlighted on the Toolbar.
To configure a Drivetrain, select the Robot Configuration button to open the Robot Configuration window. A project must be open in order to use the Robot Configuration window.
VEXcode Pro V5 Robot Configuration menu is open and the ‘Add a device’ option is shown.
Select “Add a device.”
Device selection window with ‘Drivetrain’ option highlighted.
Select “Drivetrain.”
Port selection screens showing left and right motor ports being assigned on the V5 Brain.
Select which port the Left Motor and Right Motor is attached to on the VEX V5 Brain. Ports that are already configured for other devices will be unavailable.
Robot Configuration window with ‘No Gyro’ option selected for the drivetrain.
Select "No Gyro" to turn the Gyro off.
Drivetrain settings window with Done button highlighted to confirm configuration.
Once the Drivetrain has been configured, select “Done” to submit the device to the configuration or “Cancel” to return back to the Robot Configuration window.
Note: Selecting “Cancel” will undo any changes you have made to the device and will not be a part of the configuration.
Note: If you are not configuring the Drivetrain for a VEX V5 Clawbot or Speedbot, see the additional options below.
Changing a Drivetrain’s Port Numbers
Drivetrain settings window with port selection icons highlighted and port selection menus for left and right motors.
You can change the port number for the Left Motor or Right Motor in the Drivetrain by selecting the device’s plug icon in the top right corner of the Drivetrain Settings window.
Side by side screenshots to demonstrate the Ports being changed for both the left and right motors.
Select a different port on the Port Selection window and the port number will turn blue. Then select "Done" to submit the change.
Changing a Drivetrain’s Wheel Size
Drivetrain settings showing wheel size dropdown menu with multiple size options.
You can change the wheel size for the Drivetrain by selecting the drop down menu under “Wheel Size.”
Note: The default values are for the VEX V5 Clawbot and Speedbot. If you are using the Clawbot or Speedbot, you do not need to change the values.
Changing a Drivetrain’s Track Width
Drivetrain settings with track width value field selected for adjustment.
You can change the size of the track width for the Drivetrain by entering the values in the number box and by selecting the drop down menu under “Track Width.” The track width is the measurement between the middle of the front left wheel to the middle of the front right wheel.
Changing a Drivetrain’s Gear Ratio
Drivetrain settings showing input and output fields used to adjust gear ratio.
You can change the gear ratio for the Drivetrain by entering values in the “Input” and “Output” boxes.
Reversing a Drivetrain
Drivetrain settings with directional arrows indicating option to reverse drivetrain direction.
The Drivetrain Settings window also allows the direction of the Drivetrain to be reversed.
Deleting a Drivetrain
Drivetrain settings window with Delete button highlighted below.
A Drivetrain can also be deleted by selecting the “Delete” option at the bottom of the window.
Changing a Gear Cartridge
Drivetrain settings showing gear cartridge options for selecting motor speed configurations.
The Drivetrain Settings window also allows the gear cartridge to be changed.
