Using Help in VEXcode Pro V5
Help inside of VEXcode Pro V5 can provide users with an explanation of how to use a command in their project.
Opening the Help Window
VEXcode Pro V5 toolbar with Help icon highlighted in the top right corner.
Click on the Help icon to open the Help window. The Help icon is the question mark icon at the top right of VEXcode Pro V5.
VEXcode Pro V5 Help panel open showing empty Command Help tab with instructions to right-click a method to view its Help information.
An empty Help window will appear by default.
Getting Help for a Command
VEXcode Pro V5 Help panel showing Drivetrain.drive() command documentation with description and usage examples.
In order to see the help, right-click on the command. For example: Drivetrain.drive(forward);
In this example, Drivetrain is the Device name, drive is the Command name, and the information in the parenthesis are the Parameters.
Right-click on a command name in your project and select “Command Help” to learn more about how to use the command. Information about that command will appear in the Help window.
VEXcode Pro V5 Help panel showing list of command options for different devices such as Brain Screen, Bumper, Controller, and Limit.
If multiple devices share the same command name, you will get a request to select the device you want help with. You can select a device by clicking on the name of the command from the list provided.
VEXcode Pro V5 with the Tools menu highlighted in the top left corner.
If no command help could be found, take a look at our “Advanced Help” tab. You can access “Advanced Help” by clicking on “Tools” on the top menu.
VEXcode Pro V5 Tools menu open with Open Advanced Help (In Browser) option highlighted.
Then select “Open Advanced Help (In Browser)”.
Accessing the Command Reference
VEXcode Pro V5 Help panel showing Command Reference tab with expandable categories including Drivetrain, Looks, Events, Control, and Sensing.
The Command Reference contains a list of commands available for each device configured inside of your project.
Closing the Help Window
VEXcode Pro V5 toolbar with Help icon highlighted to indicate that it can be clicked to close the Help panel.
Click the Help button in the toolbar again to close the Help window.
