This program shows how to program the V5 Clawbot to move forward and backward using VEXcode Pro V5.
main.cpp
// ---- START VEXCODE CONFIGURED DEVICES ----
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Drivetrain drivetrain 1, 10, D
// ClawMotor motor 3
// ArmMotor motor 8
// ---- END VEXCODE CONFIGURED DEVICES ----
#include "vex.h"
using namespace vex;
int main() {
// Initializing Robot Configuration. DO NOT REMOVE!
vexcodeInit();
// drives forward for 300 millimeters.
Drivetrain.driveFor(300, mm);
// drives reverse for 300 millimeters.
Drivetrain.driveFor(-300, mm);
}How it Works
This program uses the driveFor(distance, units) command to drive for a specified distance.
You can specify the units of distance by using a numeric value. You can specify units by using inches or mm (millimeters).
You can use a positive numeric value to move your robot forward and a negative numeric value to move the robot backward.
Steps executed in the program:
- The drivetrain will drive six inches forward.
- The program will wait one second before executing the next line of code.
- The drivetrain will drive six inches in reverse.
