Get more with VEXcode
We recommend you transition to our new software. VEXcode has both block-based and text-based options, that work on Chromebooks, iPads, Android tablets, Windows and Macs. Visit code.vex.com for more details on how to download VEXcode.
VEX Coding studio has been discontinued and is no longer available for download. Already downloaded? The program will continue to function but will no longer be supported.
Users who transition to VEXcode can migrate their C++/C++ Pro projects to VEXcode Pro V5 by following this article.
Step 1: Add Vision1.largestObject.angle() to VCS
  • Add the code pictured above inside the curly brackets of int main().
Step 2: Configure the Vision Sensor in VCS
Step 3: Configure Another Color Signature
  • Repeat steps 4-8 to record another color signature. Make sure to click the set button for signature two, SIG_2.  When complete, the objects will be labeled SIG_1 and SIG_2 appropriately.
Step 4: Create a Code for the Vision Sensor
  • Click on the Codes tab, and in the first gray box name the code “CODE_1”. In the white box to the right type in “1,2” the numbers of the set signatures. The Vision utility will autocomplete to SIG_1,SIG_2.
  • If the Vision utility does not autocomplete, just type “SIG_1,SIG_2” into the white box.
  • Notice that the Vision sensor and utility is now tracking the pair as “Sig 12”.
  • The angle is calculated when a group of signatures is coded and tracked together.
  • When the signatured objects are rotated clockwise the angle will decrease negatively, and when rotated counterclockwise the angle will increase positively.
Step 5: Move to the Zero Angle Position
  • Move the SIG_1 object to the left of SIG_2 right in a horizontal position. This will place the “Sig 12” objects at the zero angle position.
  • Switch the position of the objects. This will place “Sig 12” objects in the negative 180 degree angle position.
  • With the live feed from the Vision Sensor active, try rotating the pair to increase and decrease the angle.
Step 6: Move to the Positive 90 Degree Angle Position
  • Place the SIG_1 object below the SIG_2 in a vertical position. This will place “Sig 12” objects at the positive 90 degree angle position.
Step 7: Move to the Negative 90 Degree Angle Position
  • Move the SIG_1 object above SIG_2 in a vertical position. This will place “Sig 12” objects at the negative 90 degree angle position.
