This example program shows how to program the V5 Clawbot to use remote control values to move your robot's claw and arm.
robot-config.h
using namespace vex; vex::brain Brain; vex::motor LeftMotor (vex::PORT1, vex::gearSetting::ratio18_1,false); vex::motor RightMotor (vex::PORT10, vex::gearSetting::ratio18_1,false); vex::motor ClawMotor (vex::PORT3, vex::gearSetting::ratio18_1,true); vex::motor armMotor (vex::PORT8, vex::gearSetting::ratio18_1,true); vex::controller Controller1 = vex::controller();
main.cpp
#include "robot-config.h" int main() { //Use these variables to set the speed of the arm and claw. int armSpeedPCT = 50; int clawSpeedPCT = 50; while(true) { if(Controller1.ButtonUp.pressing()) { ArmMotor.spin(directionType::fwd, armSpeedPCT, velocityUnits::pct); } else if(Controller1.ButtonDown.pressing()) { ArmMotor.spin(directionType::rev, armSpeedPCT, velocityUnits::pct); } else { ArmMotor.stop(brakeType::brake); } if(Controller1.ButtonA.pressing()) { ClawMotor.spin(directionType::fwd, clawSpeedPCT, velocityUnits::pct); } else if(Controller1.ButtonY.pressing()) { ClawMotor.spin(directionType::rev, clawSpeedPCT, velocityUnits::pct); } else { ClawMotor.stop(brakeType::brake); } task::sleep(20); } }
How it works
First, the main
function is declared. An infinite while
loop is created so that the program can pull the remote control values every iteration. This loop causes the program to run forever.
Next, if ButtonUp on the controller is .pressing
, the arm motor will spin forward.
If ButtonDown on the controller is .pressing
, the arm motor will spin backward.
If neither button is being pressed, the armMotor will stop
Then, if ButtonA is .pressing
If ButtonY on the controller is .pressing
Then, add a sleep
task for a short amount of time to prevent wasted energy.
