Finding Project Files on an Android Tablet in VEXcode IQ
VEXcode IQ projects are stored on your Android Tablet’s file system. To find these files to delete or transfer to another device, you will need to use your tablet’s file manager to complete these actions.
The example shown below may look different compared to the tablet you are using. Each file manager app is different depending on the tablet, so you will need to locate the VEXcode IQ saved files folder on your device:
File manager window on an Android device, with the Internal Storage folder highlighted.
Open a file manager application on your tablet.
Find the local storage area - it may be called “Internal storage”.
File manager window on an Android device with the VEXcode IQ folder located and opened. The menu lists saved VEXcode IQ projects. Above, the file path is highlighted and reads Internal Storage to VEXcode to VEXcodeBlocks IQ.
Locate and open the VEXcode folder.
Locate and open the VEXcodeBlocks IQ storage folder.
From here, you can manage your VEXcode IQ projects just as you would any other file on your Android tablet.
