New Project - Get Started - VEXcode IQ
A new Blocks project opens any time you start VEXcode IQ. But, you can also open a new Blocks or Text project after VEXcode IQ has already started.
This article will cover the following topics:
  • Open a Template
  • Open a Blank Project
Note: when starting a new project, a prompt will appear asking you to save if the current project has not been saved yet.
Open a Template
Templates have a special icon and are used to create a blank project with a preset device configuration.
Open the File menu and select ‘Open Examples’ to open a template project.
If using a standard robot build, like the Clawbot, a Template can be used to quickly get started with a new project.
Open the File menu and select ‘New Blocks Project’ to open a new Blocks project.
To open a new Text project, open the File menu, and select ‘New Text Project.’
