Mounting and Wiring the V5 Vision Sensor
Step 1: Collect the parts you will need
The parts needed are:
90 Degree Flat Gusset piece.
(1) 90 Degree Flat Gusset from the 90 Degree Gusset Pack (276-7761)
Angle Gusset piece.
(1) Angle Gusset from the Gusset Pack (276-1110)
1 Inch Standoff piece.
(2) 1.00" Standoff from the 1.00" Standoff (10-pack) (275-1016)
#8-32 x 3/8 Inch Star Drive Screw piece.
(8) #8-32 x 3/8" Star Drive Screw from the #8-32 x 3/8" Star Drive Screw (100-pack) (276-4991)
Step 2: Attach the Mount to the Top of the V5 Claw
V5 Clawbot with the Claw modified to add supports for the Vision Sensor.
Attach the Angle Gusset to the two 1.00” Standoffs using two #8-32 x 3/8" Star Drive Screws.
Next, Attach the 1.00” Standoffs to the 90 Degree Flat Gusset using two #8-32 x 3/8" Star Drive Screws from the bottom of the Plate.
Attach the 90 Degree Flat Gusset to the top of the Claw using two #8-32 x 3/8" Star Drive Screws.
NOTE: Other sensors can use the same mounting method.
Step 3: Attach the Vision Sensor
V5 Clawbot with supports added to its Claw and the Vision Sensor mounted to the supports.
Use the screwdriver to secure the Angle Gusset into the back of the Vision Sensor by using two #8-32 x 3/8" Star Drive Screws.
Bend the Angle Gusset down so that the Vision Sensor is at the desired angle.
Use a Smart Cable to connect the Vision Sensor to a Smart Port on the V5 Robot Brain.
NOTE: When mounting the Vision Sensor, ensure that it is upright and horizontal in order to avoid coding issues.
