Configuring a 2-Motor Drivetrain in VEXcode IQ (1st gen)
Using VEX IQ (2nd generation)? See this article.
When starting to program with VEXcode IQ, blocks from the Drivetrain category will not appear in the Toolbox until a Drivetrain has been configured.
You can only configure one Drivetrain per project.
If you are configuring a Drivetrain without a Gyro Sensor, see this article
Adding a Drivetrain
VEXcode IQ Toolbar with the Devices icon highlighted in between the Code Viewer and the Help icons.
To configure a Drivetrain, select the Devices button to open the Devices window.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting is highlighted and it is set to the 1st gen option.
Select the generation that you are working with.
VEXcode IQ Devices menu with the Add a device button highlighted.
Select “Add a device.”
VEXcode IQ Devices menu after the Add a device button has been selected. The Drivetrain 2 motor option is highlighted.
Select 'Drivetrain 2-Motor.'
Three screenshots side by side that show the process of selecting Ports for the Left Motor and then the Right Motor. Lastly, the Gyro Port is selected.
Select which ports the Left Motor, Right Motor, and the Gyro Sensor are attached to on the VEX IQ Brain. Ports that are already configured for other devices will be unavailable.
VEXcode IQ Devices menu after selecting the Drivetrain Ports and with the Drivetrain Settings screen shown. Below, the Done button is highlighted.
Once the Drivetrain has been configured, select “Done” to complete the configuration or “Cancel” to return back to the Devices menu.
Note: Selecting “Cancel” will undo any changes you have made to the device and will not be a part of the configuration.
Changing a Drivetrain’s Port Numbers
VEXcode IQ Devices window with the Drivetrain Settings menu shown. Above, the icons of the Left Motor, Right Motor, and Gyro Ports are highlighted.
You can change the port number for the Left Motor, Right Motor, or Gyro in the Drivetrain by selecting the device’s plug icon in the top right corner of the Options screen.
Three screenshots side by side that show the Port Selection menu being used to change already set Port numbers for the Motors and Gyro. Previously selected Ports will show green, and after selecting the new ones the user can press Done to save the changes.
Select a different port on the Port Selection screen and the port number will turn green.
Then, select Done to submit the change.
Changing a Drivetrain’s Wheel Size
VEXcode IQ Devices window with the Drivetrain Settings menu shown. The Wheel Size dropdown menu is highlighted.
You can change the wheel size for the Drivetrain by selecting the dropdown menu under “Wheel Size.”
Changing a Drivetrain’s Gear Ratio
VEXcode IQ Devices window with the Drivetrain Settings menu shown. The Gear Ratio options are highlighted. There is an input field and an output field, and a symbol indicating that the numbers represent a ratio.
You can change the gear ratio for the Drivetrain by entering values in the “Input” and “Output” boxes.
Reversing a Drivetrain
VEXcode IQ Devices window with the Drivetrain Settings menu shown. The reverse arrow has been selected to change the Drivetrain's direction.
The Options screen also allows the direction of the Drivetrain to be reversed.
Deleting a Drivetrain
VEXcode IQ Devices window with the Drivetrain Settings menu shown. Below, the Delete button is highlighted.
A Drivetrain can be deleted by selecting the “Delete” option at the bottom of the screen.
