Updating the V5 Controller Firmware
Connect a V5 Smart Cable to your V5 Controller.
Close up of a Smart Cable connected to one of the V5 Controller's Smart Ports.
Connect one end of a V5 Smart Cable to one of the Smart Ports located on the top of the V5 Controller.
Connect your V5 Controller to your V5 Robot Brain.
V5 Brain is shown with the Controller's Smart Cable connected to one of the Brain's Smart Ports.
Connect the opposite end of the V5 Smart Cable into any open Smart Port on the V5 Robot Brain.
Power on your V5 Brain, if it is not already powered on.
V5 Brain is shown powered on and with wired connections to a V5 Controller and a V5 Robot Battery.
Make sure your V5 Robot Brain has a charged V5 Robot Battery connected.
Press the Power button on the V5 Robot Brain to power it on if it is not already turned on.
Confirm the firmware update.
V5 Brain is shown with an orange background and a message that reads The controller firmware requires an update. Would you like to proceed? Below, there are two buttons reading OK and Cancel.
If your V5 Controller's firmware is not current to the firmware on the V5 Robot Brain, you will see this screen.
Press OK to begin the firmware update for the V5 Wireless Controller.
V5 Brain is shown with an orange background and a message that reads The controller assets require an update. Would you like to proceed? Below, there are two buttons reading OK and Cancel.
You may also be prompted to update the controller assets. If so, press OK a second time.
