Running User Programs from the VEX IQ Brain
VEX IQ (2nd gen) Brain
User Programs downloaded to the Brain can be found in one of 8 slots for User Programs, numbered 1 - 8 in the Programs menu.
Use the left and right buttons to highlight the Programs menu option, then press the Check button to select Programs.
In the Programs menu, you will see the User Programs downloaded to the Brain. In this example image, there are two User Programs downloaded in slot 1 (My Project) and slot 2.
  • Use the left and right buttons to scroll to your desired project.
  • Press the Check button to select the program.
Once your project is selected, you can run your project.
  • Use the left and right buttons to scroll to your desired run option.
  • Press the Check button run your project.
VEX IQ (1st gen) Brain
User Programs downloaded to the Brain can be found in one of four slots for User Programs, numbered 1, 2, 3, and 4 in the Programs menu.
NOTE: This Brain has three User Programs downloaded to it: GraphicalProgram (Slot 1), MoveFastThenStop1 (Slot 3), and ScaledRectangle (Slot 4). Slot 2 does not have a User Program downloaded to it.
  • Find and run the program in the menu.
  • Run the program by pressing the Check button. It will automatically begin to run after the Check button is pressed.
