Running User Programs - IQ Brain (2nd gen)
VEX IQ (2nd gen) Brain
User Programs downloaded to the Brain can be found in one of 8 slots for User Programs, numbered 1 - 8 in the Programs menu.
Brain screen is shown in the Home menu with the Programs option selected. Programs is the second option in the Home menu.
Use the left and right buttons to highlight the Programs menu option, then press the Check button to select Programs.
Brain screen is shown in the Programs menu with a VEXcode Project in slot 1 selected and named MyProject.
In the Programs menu, you will see the User Programs downloaded to the Brain. In this example image, there are two User Programs downloaded in slot 1 (My Project) and slot 2.
  • Use the left and right buttons to scroll to your desired project.
  • Press the Check button to select the program.
Brain screen is shown in the Project menu for the project named MyProject. The Run option is selected.
Once your project is selected, you can run your project.
  • Use the left and right buttons to scroll to your desired run option.
  • Press the Check button run your project.
