Mounting and Wiring the V5 Motor
Tips on Attaching Motors to a Build
Watch the video below to learn tips on how to attach a V5 Smart Motor to a build.
Collect the parts that you will need.
Parts needed to mount and wire the V5 Smart Motor.
You will need the following:
  • (1) V5 Smart Motor (not shown)
  • (2) #8-32 x 1/2" Screws
  • (1) 5-64" Hex Key
  • (1) 3-32" Hex Key
  • (1) Shaft Coupler
  • (1) 1/2" Shaft
Position the V5 Smart Motor.
V5 Clawbot that uses V5 Smart Motors to control its Claw Arm and open and close the Claw.
Position the V5 Smart Motor to turn a wheel, the Claw Arm, or the Claw.
This example will focus on the V5 Smart Motor powering the movement of the Claw Arm.
Secure and wire the V5 Smart Motor.
Close up of a V5 Smart Motor securely mounted to the V5 Clawbot, with a Smart Cable connecting it to the V5 Brain.
Use the tools that you assembled to securely mount the V5 Smart Motor to the top of the V5 Clawbot's arm support structure.
  • Make sure that the motor is mounted so that it properly aligns and is able to turn the gear.
Use a Smart Cable to connect your new V5 Smart Motor to Port 8 on your V5 Robot Brain.
