Resetting the V5 Brain to Default Values
Make sure that the V5 Robot Brain is on.
Brain powered on with the screen showing the Home menu.
Have your V5 Robot Battery charged and connected to the V5 Robot Brain so that you can power it on.
Tap the Settings icon.
Brain screen is shown in the Home menu with the Settings option highlighted.
Select the Settings icon by tapping on it to bring up the Settings menu.
Tap Reset settings.
Brain screen is shown in the Settings menu with the Reset settings option highlighted. This menu has many options that can be customized. The options in this screenshot read Language English, Start at Home, Backlight 100%, Theme Dark, Rotation Normal, and Radio VEXnet. There are also system options on the right that read Reset settings, Delete programs, and Regulatory.
Choose the option for resetting the settings at the top of the right column.
Tap OK on the Confirm screen.
Brain screen is shown after the Reset settings option has been selected. The screen has an orange background and reads Confirm, Reset all Robot Brain settings to factory defaults? There are two buttons below reading OK and Cancel, and the OK button is highlighted.
Tap OK to restore the default settings when this screen is shown.
The factory defaults should all be restored.
