Users can access the "Command Palette" from inside of VEXcode Pro V5 to access all editor commands and see their keyboard shortcut from directly inside VEXcode Pro V5 - use the F1 key on your keyboard to bring up the "Command Palette".
Command | Windows Shortcut | Mac Shortcut |
Add Cursor Above | Ctrl + Alt + UpArrow | Option + Command + UpArrow |
Add Cursor Below | Ctrl + Alt + DownArrow | Option + Command + DownArrow |
Add Cursors to Line Ends (Multi-Cursor) | Shift + Alt + I | Shift + Option + I |
Add Line Comment | Ctrl + K (then) Ctrl + C | Command + K (then) Command + C |
Add Selection to Next Find Match | Ctrl + D | Command + D |
Change All Occurrences | Ctrl + F2 | Command + F2 |
Close Window | Alt + F4 | Command + W |
Command Palette | F1 | F1 |
Copy | Ctrl + C | Command + C |
Copy Line Down | Shift + Alt + DownArrow | Shift + Option + DownArrow |
Copy Line Up | Shift + Alt + UpArrow | Shift + Option + UpArrow |
Cut | Ctrl + X | Command + X |
Delete All Left | (N/A) | Command + Backspace |
Delete All Right | (N/A) | Option + K |
Delete Whole Line | Ctrl + Shift + K | Shift + Command + K |
Editor Font Zoom In (Larger) | Ctrl + DownArrow | Command + DownArrow |
Editor Font Zoom Out (Smaller) | Ctrl + UpArrow | Command + UpArrow |
Expand Select | Shift + Alt + RightArrow | Option + Shift + Command + LeftArrow |
Find | Ctrl + F | Command + F |
Find Next | F3 | Command + G |
Find Next Selection | Ctrl + F3 | Command + F3 |
Find Previous | Shift + F3 | Shift + Command + G |
Find Previous Selection | Ctrl + Shift + F3 | Shift + Command + F3 |
Find With Selection | (N/A) | Command + E |
Fold | Ctrl + Shift + [ | Option + Command + [ |
Fold All | Ctrl + K (then) Ctrl + 0 | Command + K (then) Command + 0 |
Fold All Block Comments | Ctrl + K (then) Ctrl + / | Command + K (then) Command + / |
Fold All Regions | Ctrl + K (then) Ctrl + 8 | Command + K (then) Command + 8 |
Fold Level 1 | Ctrl + K (then) Ctrl + 1 | Command + K (then) Command + 1 |
Fold Level 2 | Ctrl + K (then) Ctrl + 2 | Command + K (then) Command + 2 |
Fold Level 3 | Ctrl + K (then) Ctrl + 3 | Command + K (then) Command + 3 |
Fold Level 4 | Ctrl + K (then) Ctrl + 4 | Command + K (then) Command + 4 |
Fold Level 5 | Ctrl + K (then) Ctrl + 5 | Command + K (then) Command + 5 |
Fold Level 6 | Ctrl + K (then) Ctrl + 6 | Command + K (then) Command + 6 |
Fold Level 7 | Ctrl + K (then) Ctrl + 7 | Command + K (then) Command + 7 |
Fold Recursively | Ctrl + K (then) Ctrl + [ | Command + K (then) Command + [ |
Format Document | Shift + Alt + F | Shift + Option + F |
Go to Bracket | Ctrl + Shift + \ | Shift + Command + \ |
Go to Definition | Ctrl + F12 | Command + F12 |
Go to Line... | Ctrl + G | Control + G |
Go to Next Problem in Files | F8 | F8 |
Go to Previous Problem in Files | Shift + F8 | Shift + F8 |
Go to Symbol... | Ctrl + Shift + O | Shift + Command + O |
Indent Line | Ctrl + ] | Command + ] |
Insert Line Above | Ctrl + Shift + Enter | Shift + Command + Enter |
Join Lines | (N/A) | Control + J |
Move Caret Left | LeftArrow | LeftArrow |
Move Caret Right | RightArrow | RightArrow |
Move Last Selection to Next Find Match | Ctrl + K (then) Ctrl + D | Command + K (then) Command + D |
Move Line Down | Alt + DownArrow | Option + DownArrow |
Move Line Up | Alt + UpArrow | Option + UpArrow |
Open Definition to the Side | Ctrl + K (then) Ctrl + 12 | Command + K (then) Command + F12 |
Outdent Line | Ctrl + [ | Command + [ |
Paste | Ctrl + V | Command + V |
Peek Definition | Alt + F12 | Command + F12 |
Quick Fix... | Ctrl + . (Period) | Command + . (Period) |
Refactor... | Ctrl + Shift + R | Option + Shift + R |
Redo | Ctrl + Y | Shift + Command + Z |
Remove Line Comment | Ctrl + K (then) Ctrl + U | Command + K (then) Command + U |
Rename Symbol | F2 | F2 |
Replace | Ctrl + H | Option + Command + F |
Replace with Next Value | Ctrl + Shift + . (Period) | Shift + Command + . (Period) |
Replace with Previous Value | Ctrl + Shift + , (Comma) | Shift + Command + , (Comma) |
Save | Save + S | Command + S |
Select All | Ctrl + A | Command + A |
Select All Occurrence of Find Match | Ctrl + Shift + L | Shift + Command + L |
Show Editor Context Menu | Shift + F10 | Shift + F10 |
Show Hover | Ctrl + K (then) Ctrl + I | Command + K (then) Command + I |
Shrink Select | Shift + Alt + LeftArrow | Control + Shift + Command + LeftArrow |
Soft Undo | Ctrl + U | Command + U |
Toggle Block Comment | Shift + Alt + A | Shift + Option + A |
Toggle Line Comment | Ctrl + / | Command + / |
Toggle Tab Key Moves Focus | Ctrl + M | Option + Shift + M |
Transpose Letters | (N/A) | Option + T |
Trigger Parameter Hints | Ctrl + Shift + Space | Shift + Command + Space |
Trigger Suggest | Ctrl + Space | Control + Space |
Trim Trailing Whitespace | Ctrl + K (then) Ctrl + X | Command + K (then) Command + X |
Undo | Ctrl + Z | Command + Z |
Unfold | Ctrl + Shift + ] | Option + Command + ] |
Unfold All | Ctrl + K (then) Ctrl + J | Command + K (then) Command + J |
Unfold All Regions | Ctrl + K (then) Ctrl + 9 | Command + K (then) Command + 9 |
Unfold Recursively | Ctrl + K (then) Ctrl + ] | Command + K (then) Command + ] |
