Keyboard Shortcuts - Tutorials
Users can access the "Command Palette" from inside of VEXcode Pro V5 to access all editor commands and see their keyboard shortcut from directly inside VEXcode Pro V5 - use the F1 key on your keyboard to bring up the "Command Palette".
Command
Windows Shortcut
Mac Shortcut
Add Cursor Above
Ctrl + Alt + UpArrow
Option + Command + UpArrow
Add Cursor Below
Ctrl + Alt + DownArrow
Option + Command + DownArrow
Add Cursors to Line Ends (Multi-Cursor)
Shift + Alt + I
Shift + Option + I
Add Line Comment
Ctrl + K (then) Ctrl + C
Command + K (then) Command + C
Add Selection to Next Find Match
Ctrl + D
Command + D
Change All Occurrences
Ctrl + F2
Command + F2
Close Window
Alt + F4
Command + W
Command Palette
F1
F1
Copy
Ctrl + C
Command + C
Copy Line Down
Shift + Alt + DownArrow
Shift + Option + DownArrow
Copy Line Up
Shift + Alt + UpArrow
Shift + Option + UpArrow
Cut
Ctrl + X
Command + X
Delete All Left
(N/A)
Command + Backspace
Delete All Right
(N/A)
Option + K
Delete Whole Line
Ctrl + Shift + K
Shift + Command + K
Editor Font Zoom In (Larger)
Ctrl + DownArrow
Command + DownArrow
Editor Font Zoom Out (Smaller)
Ctrl + UpArrow
Command + UpArrow
Expand Select
Shift + Alt + RightArrow
Option + Shift + Command + LeftArrow
Find
Ctrl + F
Command + F
Find Next
F3
Command + G
Find Next Selection
Ctrl + F3
Command + F3
Find Previous
Shift + F3
Shift + Command + G
Find Previous Selection
Ctrl + Shift + F3
Shift + Command + F3
Find With Selection
(N/A)
Command + E
Fold
Ctrl + Shift + [
Option + Command + [
Fold All
Ctrl + K (then) Ctrl + 0
Command + K (then) Command + 0
Fold All Block Comments
Ctrl + K (then) Ctrl + /
Command + K (then) Command + /
Fold All Regions
Ctrl + K (then) Ctrl + 8
Command + K (then) Command + 8
Fold Level 1
Ctrl + K (then) Ctrl + 1
Command + K (then) Command + 1
Fold Level 2
Ctrl + K (then) Ctrl + 2
Command + K (then) Command + 2
Fold Level 3
Ctrl + K (then) Ctrl + 3
Command + K (then) Command + 3
Fold Level 4
Ctrl + K (then) Ctrl + 4
Command + K (then) Command + 4
Fold Level 5
Ctrl + K (then) Ctrl + 5
Command + K (then) Command + 5
Fold Level 6
Ctrl + K (then) Ctrl + 6
Command + K (then) Command + 6
Fold Level 7
Ctrl + K (then) Ctrl + 7
Command + K (then) Command + 7
Fold Recursively
Ctrl + K (then) Ctrl + [
Command + K (then) Command + [
Format Document
Shift + Alt + F
Shift + Option + F
Go to Bracket
Ctrl + Shift + \
Shift + Command + \
Go to Definition
Ctrl + F12
Command + F12
Go to Line...
Ctrl + G
Control + G
Go to Next Problem in Files
F8
F8
Go to Previous Problem in Files
Shift + F8
Shift + F8
Go to Symbol...
Ctrl + Shift + O
Shift + Command + O
Indent Line
Ctrl + ]
Command + ]
Insert Line Above
Ctrl + Shift + Enter
Shift + Command + Enter
Join Lines
(N/A)
Control + J
Move Caret Left
LeftArrow
LeftArrow
Move Caret Right
RightArrow
RightArrow
Move Last Selection to Next Find Match
Ctrl + K (then) Ctrl + D
Command + K (then) Command + D
Move Line Down
Alt + DownArrow
Option + DownArrow
Move Line Up
Alt + UpArrow
Option + UpArrow
Open Definition to the Side
Ctrl + K (then) Ctrl + 12
Command + K (then) Command + F12
Outdent Line
Ctrl + [
Command + [
Paste
Ctrl + V
Command + V
Peek Definition
Alt + F12
Command + F12
Quick Fix...
Ctrl + . (Period)
Command + . (Period)
Refactor...
Ctrl + Shift + R
Option + Shift + R
Redo
Ctrl + Y
Shift + Command + Z
Remove Line Comment
Ctrl + K (then) Ctrl + U
Command + K (then) Command + U
Rename Symbol
F2
F2
Replace
Ctrl + H
Option + Command + F
Replace with Next Value
Ctrl + Shift + . (Period)
Shift + Command + . (Period)
Replace with Previous Value
Ctrl + Shift + , (Comma)
Shift + Command + , (Comma)
Save
Save + S
Command + S
Select All
Ctrl + A
Command + A
Select All Occurrence of Find Match
Ctrl + Shift + L
Shift + Command + L
Show Editor Context Menu
Shift + F10
Shift + F10
Show Hover
Ctrl + K (then) Ctrl + I
Command + K (then) Command + I
Shrink Select
Shift + Alt + LeftArrow
Control + Shift + Command + LeftArrow
Soft Undo
Ctrl + U
Command + U
Toggle Block Comment
Shift + Alt + A
Shift + Option + A
Toggle Line Comment
Ctrl + /
Command + /
Toggle Tab Key Moves Focus
Ctrl + M
Option + Shift + M
Transpose Letters
(N/A)
Option + T
Trigger Parameter Hints
Ctrl + Shift + Space
Shift + Command + Space
Trigger Suggest
Ctrl + Space
Control + Space
Trim Trailing Whitespace
Ctrl + K (then) Ctrl + X
Command + K (then) Command + X
Undo
Ctrl + Z
Command + Z
Unfold
Ctrl + Shift + ]
Option + Command + ]
Unfold All
Ctrl + K (then) Ctrl + J
Command + K (then) Command + J
Unfold All Regions
Ctrl + K (then) Ctrl + 9
Command + K (then) Command + 9
Unfold Recursively
Ctrl + K (then) Ctrl + ]
Command + K (then) Command + ]
