Autopilot Program in the Demos Folder - Get Started - VEXcode IQ Blocks
The Autopilot Program is a default program built into the VEX IQ Robot Brain so it can be used with the Autopilot build without programming. The Autopilot Program has three modes: Random, Spiral, and Lawnmower.
Random Mode Behavior
The robot will explore by driving in a straight line.
When it encounters an obstacle, it will back up, spin a random
amount, and proceed in a new direction.
When the Touch LED is tapped or the Color Sensor sees
blue, the robot will switch to Spiral Mode.
Spiral Mode The robot will explore by driving in a spiral.
When it encounters an obstacle, the robot will drive to a
new location and begin to spiral again.
sees green, the robot will switch to Lawnmower Mode.
Lawnmower Mode The robot will explore by driving back and forth as if
mowing a lawn. When it encounters an obstacle, it will
turn away and proceed in the opposite direction.
sees red, the robot will switch to Random Mode.
Step 1: Check that the Smart Ports are properly wired.
Smart Port Number Device
1 Left Motor Drive
2 Distance Sensor
3 Color Sensor
4 Gyro Sensor
5 Touch LED
6 Right Drive Motor
7 Not Used
8 Back Left Bumper Switch
9 Back Right Bumper Switch
10 Not Used
11 Not Used
12 Right Drive Motor
  • Check that Smart Ports 1-12 have the device listed in the table above.
NOTE: To review how to connect devices to Smart Ports properly, click here
Step 2: Find and Run the Autopilot program.
  • After powering on the Brain, highlight and press the Check button to select Demos.
  • Highlight and press the Check button to start the Autopilot program.
NOTE: The Brain will alert you if the Smart Ports are missing the proper sensors or motors.
  • Allow the Autopilot program to control the robot’s behaviors.
