Selecting a Language on the V5 Brain
Make sure the V5 Robot Brain is on
Brain powered on with the screen showing the Home menu.
Turn on the V5 Robot Brain by pressing and holding the Home button on the brain.
Select the Settings icon
Brain screen is shown in the Home menu with the Settings option highlighted.
Tap on the Settings icon highlighted in the red rectangle in the image above.
Select the Language setting
Brain screen is shown in the Settings menu with the Language option highlighted. This menu has many options that can be customized. The options in this screenshot read Language English, Start at Home, Backlight 100%, Theme Dark, Rotation Normal, and Radio VEXnet. There are also system options on the right that read Reset settings, Delete programs, and Regulatory.
Tap on the Language setting highlighted in the red rectangle in the image above.
Select the desired language.
