Running the Drive Built-In Program using the V5 Controller
Make sure that your V5 Controller is on and linked to your V5 Robot.
Screenshot from the Brain is shown above a screenshot from the Controller. Both of the screens have a wireless connection icon in the top right icon, indicating that they are connected.
The V5 Controller should be powered on and connected to your V5 Robot.
For help in connecting your robot to the controller, go to this page about pairing your V5 Controller to your V5 Robot Brain.
Make sure that the Drive icon is highlighted and press the A button.
Controller screen is shown in the Home menu with the Drive option highlighted. The Drive option is the first option in the Home menu.
Use the arrow buttons on the V5 Controller to move the dark highlight over the Drive icon.
Then press either the down-arrow button or the A button to select Drive.
Press A to run the Drive program.
Controller screen is shown in the Drive menu with the Run option highlighted. Run is the first option in the menu.
Use the arrow buttons to move the dark highlight over the Run icon on the Drive program screen.
Then press the A button to select Run.
Step 4: Use the Drive program's running screen.
Three screenshots are shown in order to demonstrate how the Drive program can be run from the Home menu. First the screen is shown in the Home menu, then the Drive menu, and then the Drive project is shown actively running.
The image above shows the screens you went through to run the Drive program.
Use the Drive program's running screen to monitor your running time and the charge on the battery.
