Connecting a 3-Wire Device to the V5 Brain
Gather the required components
V5 Robot Brain, 3-Wire Potentiometer device, 3-Wire Ultrasonic Range Finder device, and a 3-Wire extension cable are shown together.
You will need the following items:
  • a V5 Robot Brain
  • a 3-Wire device
Locate the 3-Wire Ports
V5 Brain with its eight 3-Wire ports shown. These ports are labeled alphabetically from A to H.
The 3-Wire Ports are located on the side of the V5 Brain opposite the side with the battery connection.
The V5 brain has a total of eight 3-Wire ports, labeled A-H, which can all be used as inputs or outputs that can be used with VEX EDR  3-wire legacy sensors and motor controllers.
Connect the 3-Wire device.
V5 3-Wire Potentiometer device is shown connected to one of the V5 Brain's 3-Wire ports.
Insert the 3-Wire cable(s) into the desired port(s). The ports are keyed so you can only plug the cable in one way.
If you are using 3-Wire extensions, make sure the black wires are always connected to prevent connecting the device incorrectly.
