Wirelessly Downloading a Project in VEXcode Pro V5
V5 Robot Brain screen showing controller and wireless signal icons in the top right indicating connection.
Wirelessly connect the V5 Controller to the Brain or via a Smart Cable.
NOTE: The Controller must be connected to the Brain throughout the entire wireless download process. You can confirm that your controller is connected by looking at your Brain’s screen. You will see a controller and a signal icon at the top right of the screen.
VEXcode Pro V5 code editor open with project loaded and toolbar visible.
When you have your controller connected to the brain, open VEXcode Pro V5.
Laptop connected to a V5 Controller using a USB cable placed in front of the computer.
Connect the Controller to the computer via a USB cable. The Controller must be connected to the computer via a USB cable throughout the entire wireless download process.
VEXcode Pro V5 toolbar showing Controller icon highlighted in green indicating successful connection.
Check that the Controller is connected properly. This is indicated by the Controller icon being green.
VEXcode Pro V5 toolbar showing Save icon and project slot selector used to choose a Brain slot.
Save the project and then choose which of the Brain’s slots to download to.
VEXcode Pro V5 toolbar showing Brain icon highlighted in green with Download and other icons inactive.
Check that the Brain icon is green and the Download and other icons are gray.
VEXcode Pro V5 toolbar showing Download icon highlighted to send project to the Brain.
Select Download to the project to the Brain’s selected slot.
NOTE: The Download, Run, and Stop icons will turn briefly gray until the download is complete. Downloads done wirelessly take slightly longer than wired downloads.
V5 Robot Brain screen showing VEXcode project icon selected to run the program.
Finally, run the project on the Brain.
VEXcode Pro V5 toolbar showing Run icon highlighted to start the project.
You can also run the project from the toolbar.
NOTE: The project must already be downloaded before you can run the project from the toolbar.
