Opening Example Projects in VEXcode Pro V5
Launch VEXcode Pro V5
VEXcode Pro V5 application shortcut on the desktop.
Launch VEXcode Pro V5 using the desktop shortcut.
Open the Example Projects Menu
VEXcode Pro V5 interface with File menu open and Open Examples option highlighted.
Select ‘Open Examples...’ from the File drop-down menu.
Select the Example Project
Examples window showing list of projects with Adjusting Speed example selected and Next button shown below.
Select the example project and then select 'Next.'
Alternatively, double-clicking the selected example will automatically open the window for assigning the project a name.
Name and Open
Example Project window showing project name field set to AdjustingSpeed with Create button shown below.
By default, the project name will be filled in as "MyProject1." Re-name the project and select the Create button.
NOTE: The name must be under 21 characters long and cannot include spaces.
