This example program shows how to program the V5 Clawbot to turn left and right using VEXcode Pro Text.
#include "vex.h"
using namespace vex;
int main() {
// Initializing Robot Configuration. DO NOT REMOVE!
vexcodeInit();
// Turn 90 degrees to the left.
Drivetrain.turnFor(-90,degrees);
// Wait for 1 seconds.
wait(1, seconds);
// Turn 180 degrees to the right.
Drivetrain.turnFor(180, degrees);
}How it works
This program used the turnFor(degrees, units) instruction to turn the robot for a specified degree. Degrees can be specified by using a numeric value.
You can specify the units by using degrees. A positive numeric value can be used to turn the robot to the left and a positive number value to move it to the right.
Steps executed in the program:
- The Drivetrain is set to turn 90 degrees to the left.
- The program will wait 1 second before executing the next line of code.
- The Drivetrain is set to turn the robot in the opposite direction which is 180 degrees to the right.
