Open Program on Launch - VEX Coding Studio
Get more with VEXcode
We recommend you transition to our new software. VEXcode has both block-based and text-based options, that work on Chromebooks, iPads, Android tablets, Windows and Macs. Visit code.vex.com for more details on how to download VEXcode.
VEX Coding studio has been discontinued and is no longer available for download. Already downloaded? The program will continue to function but will no longer be supported.
Users who transition to VEXcode can migrate their C++/C++ Pro projects to VEXcode Pro V5 by following this article.
Step 1: While VCS is open, select a programming language and click browse
Step 2: Select a file
For Mac:
  • Select the file that you want to open.
    • If it is not saved inside of your Downloads folder (like in the image above), then you will need to select a different folder to find the file.
  • Click Open.
For Windows PC:
    • If it is not saved inside of your Projects folder on your Desktop (like in the image above), then you will need to select a different folder to find the file.
  • Click Open.
