Get more with VEXcode
We recommend you transition to our new software. VEXcode has both block-based and text-based options, that work on Chromebooks, iPads, Android tablets, Windows and Macs. Visit code.vex.com for more details on how to download VEXcode.
VEX Coding studio has been discontinued and is no longer available for download. Already downloaded? The program will continue to function but will no longer be supported.
Users who transition to VEXcode can migrate their C++/C++ Pro projects to VEXcode Pro V5 by following this article.
Step 1: Connect a Bumper Switch to your V5 Robot Brain
- Choose any available 3-Wire Port to make the connection.
- Remember the port letter of the 3-Wire Port that you used.
Step 2: Navigate to the Robot configuration window
- Open or create a Modkit or VEX C++ program in VEX Coding Studio.
- Click on the Robot button to open the graphical robot configuration view.
Step 3: Add a Bumper Switch to the configuration
- Drag a Bumper Switch from the drawer on the left into the right side configuration window.
Step 4: Assign the Bumper Switch to the 3-Wire Port you chose
- Click on the Bumper Switch, then click on the letter of the port you used.
- If you wish, give the Bumper Switch a different name in your code by changing the
Bumper1
name in the upper left text box.
