Cloud Compiler Issues - Troubleshoot - VEXcode IQ
When a user receives the error message “ Compiler process has timed out. Please try again.” or “ Unable to access the compiler server. Please try again”, this article can help troubleshoot these two errors inside of VEXcode IQ.
The VEXcode Cloud Compiler is only used on VEXcode IQ running on ChromeOS and iOS/iPadOS. VEXcode IQ running on Windows or macOS uses a local compiler and does not require internet connectivity.
Checking Cloud Compiler Connectivity
First, check to see if the VEXcode Cloud Compiler services are up and running. You can visit status.vexcode.cloud to discover if there is a service interruption to the Cloud Compiler service for all users.
If the VEXcode Cloud Compiler services are reporting as up and running, your network may be blocking access to the VEXcode Cloud Compiler. You can download the VEXcode Cloud Compiler Status Utility to assist in troubleshooting your network’s connectivity to the Cloud Compiler services.
Using the VEXcode Cloud Compiler Status Utility
Network Connection
The Network Connection indicator will display the device’s current Internet connectivity. All other connection status indicators will report “Not Connected” if there is no Internet connectivity.
IQ & V5
The IQ and V5 rows will display the status for the two VEXcode Cloud Compiler services - one for each version of VEXcode Blocks.
Compiler Service: These indicators show if the VEXcode Compiler Services are currently up and running for all users. This information is pulled from the status.vexcode.cloud website.
Network Connection to Compiler: These indicators will indicate if the current network can access to the VEXcode Cloud Compiler services. This test simulates compiling a VEXcode Blocks projects on the Cloud Compiler via an Amazon Web Services WebSocket service. This test will report “Not Connected” if the compiler is not accessible from the current network. Network Administrators will need to ensure that ChromeOS and iOS/iPadOS devices using VEXcode V5 Blocks can connect to the following servers to ensure users can compile their projects:
IQ Cloud Compiler Service
Server: prod.iq.blocks.vexcode.cloud
Port: 5636
Protocol: TCP
V5 Cloud Compiler Service
Server: prod.v5.blocks.vexcode.cloud
Port: 5636
Protocol: TCP
Refresh Button
The refresh button can be used to run the compiler test again to help validate if the network can connect to the VEXcode Cloud Compiler services. Note that the “Last Time Checked” field is the last time the status.vexcode.cloud was updated, not the last time the local utility was refreshed.
