Using Comment Blocks in VEXcode V5
Comments are usually added to projects to explain what a programmer wanted parts of the program to do. So they are helpful when collaborating and troubleshooting.
VEXcode V5 blocks workspace that shows a Comment block being dragged from the Toolbox into a stack of blocks.
Drag a “comment” block and attach it to any block in a stack.
VEXcode V5 blocks project with a Comment block that has a highlighted text field and reads Add a comment here.
Type any text, numbers, or symbols into the “comment” block.
VEXcode V5 blocks project with a Comment block that has a saved message in its text field that reads Add a comment here.
When you finish the comment, click anywhere outside of the comment or press the “Enter” or “Return” key to finish editing the comment.
Note: The inside of the comment block will turn from white to gray when finished.
