Using the Context Menu in VEXcode V5 Blocks
Right-clicking or Long-pressing in VEXcode V5 leads to many options.
The Context Menu in the Programming area
Right-clicking or Long-pressing in the Programming area in VEXcode V5 leads to the following options:
Undo: will reverse the most recent action.
For example, as shown in this video, the turn for block was deleted. Selecting “Undo” reverses that action.
Redo: will reverse the “Undo.”
In the last example, the turn for block was deleted and the “Undo” reversed that action. As shown in this video, selecting “Redo” will reverse the “Undo” so that the turn for block is deleted.
Clean up Blocks: organizes the blocks so that they are all in a vertical line, as shown in this video.
  • Delete Blocks: all of the blocks in the Programming area can be deleted at once.
For more information about deleting blocks, view the article How to Delete Blocks - VEXcode V5.
The Context Menu of Block(s)
Right-clicking or Long-pressing on a block in VEXcode V5 leads to the following options:
Duplicate Blocks: this action will make an exact copy of the blocks selected, as shown in this video.
VEXcode V5 Blocks project with an enabled block's context menu opened and the Disable Block option highlighted. Disable Block is the second option in the context menu, below Duplicate.
VEXcode V5 Blocks project containing a disabled block. The block is grayed out and has a grid of diagonal lines over it.
 Disable Blocks: This action will treat the block as a comment so that is has no effect on the project
For more information about disabling blocks, view the article How to Disable and Enable Blocks - VEXcode V5.
VEXcode V5 Blocks project with a disabled block's context menu opened and the Enable Block option highlighted. Enable Block is the third option in the context menu, below Duplicate and Disable Block.
VEXcode V5 Blocks project with the selected block enabled.
Enable Blocks: This action will enable a currently disabled block.
For more information about enabling blocks, view the article How to Disable and Enable Blocks - VEXcode V5.
  • Delete Blocks: individual or groups of blocks can be deleted.
