Deleting a Block in VEXcode IQ
Blocks in VEXcode IQ can be deleted in a number of ways.
Drag to Delete
VEXcode IQ Workspace with a block being dragged back into the Toolbox to delete it.
Select a block or a stack of blocks in the Workspace and drag them left to the Toolbox to delete from your project.
Delete a Single Block from a Stack
VEXcode IQ Workspace with a block's context menu opened and the Delete Block option highlighted.
To remove a single block from a stack, context-select (right click or long press) a block in a stack and then choose 'Delete Block' from the context menu. This will also delete any nested blocks if a block with parameters is chosen to be deleted.
Delete All Blocks
VEXcode IQ Workspace with the background's context menu opened and the Delete X blocks option highlighted. This option will delete all blocks in the workspace except for the When Started block.
To remove all of the blocks in the Workspace, context-select (right click or long press) the background of the Workspace and choose 'Delete X Blocks.'
VEXcode GO Workspace after the Delete X blocks option has been selected. A prompt reads Delete all X blocks? The user can press Cancel or Ok.
When choosing to delete all of the blocks in the Workspace, you will be asked to confirm deleting all blocks to prevent accidental deletion. A prompt will NOT appear when nested blocks are selected to be deleted.
