Configuring the default IQ Controller in VEXcode IQ (1st gen)
This article has been archived. See the updated article here.
When starting to program with VEXcode IQ, Controller blocks will not appear in the Toolbox until a Controller has been configured.
  • You can only configure one Controller per project.
  • An IQ Clawbot (drivetrain) Template is used for the following configuration of a Controller.
  • If you have a Controller configured, you must have a Controller connected to your VEX IQ Robot Brain for your project to run.
Here are the different options when configuring a Controller:
  • Adding a Controller
  • Changing a Controller’s Left and Right Buttons
  • Changing a Controller’s Joysticks
  • Changing a Controller’s E and F Buttons
  • Switching the Direction of a Controller’s Buttons
  • Deleting a Controller
Adding a Controller
VEXcode IQ Toolbar with the Devices icon highlighted in between the Code Viewer and the Help icons.
To configure a Controller, select the Devices button to open the Devices window.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting is set to the 1st gen option.
Select the generation that you are working with.
VEXcode IQ Devices menu with the Add a device button selected.
Select “Add a device.”
VEXcode IQ Devices menu after the Add a device button has been selected. The Controller option is highlighted.
Select "Controller".
VEXcode IQ Devices menu with the Controller options shown. There is a diagram of all of the buttons on the controller, and each button can be connected to Motor Groups or Drivetrains by selecting them in the diagram. Below, the Done button is highlighted.
If you want to program the Controller using VEXcode IQ, select “Done” to complete the configuration or “Cancel” to return back to the Devices menu.
Note: If you want to configure the Controller for use without programming, see the additional options below.
VEXcode IQ Devices menu with the Controller options shown. The L axis buttons are connected to a Motor labeled ClawMotor, and the R axis buttons are connected to a Motor labeled ArmMotor.
You can change which motors the Left and Right buttons control by selecting the buttons to cycle through the motors until the desired motor is shown.
Note: The motors must be configured before assigning actions to buttons.
VEXcode IQ Devices menu with the Controller options shown. The left and right joystick buttons have icons that indicate that they are connected to Split Arcade on the Drivetrain.
You can change the drive-mode of the robot by selecting the Joysticks to cycle through the modes until the desired mode is shown. The four modes are: Left Arcade, Right Arcade, Split Arcade, Tank.
Note: The Drivetrain must be configured before assigning a drive-mode.
VEXcode IQ Devices menu with the Controller options shown. The E axis buttons are connected to a Motor labeled ClawMotor, and the F axis buttons are connected to a Motor labeled ArmMotor.
You can change which motors the E and F buttons control by selecting the buttons to cycle through the motors until the desired motor is shown.
VEXcode IQ Devices menu with the Controller options shown. The L axis buttons are connected to a Motor labeled ClawMotor, and the F axis buttons are connected to a Motor labeled ArmMotor. The axes in this example aren't swapped, but there are highlighted buttons that can be used to flip the orientation of two buttons.
The Options screen also allows the swap arrow to switch which buttons control each direction of the motor.
VEXcode IQ Devices menu with the Controller options shown. The Delete button is highlighted below.
A Controller can also be deleted by selecting the “Delete” option at the bottom of the screen.
