Troubleshooting the VEX IQ (1st gen) Battery by Manually Charging
Manually charging the VEX IQ Robot Battery is a troubleshooting technique that should only be tried if the Battery is not working and charging the Battery has failed. In this situation, you will see the indicator light on the IQ Battery Charger blinking red when the Battery is inserted. Manually charging at other times could result in damage to the Robot Battery.
Step 1: Gather the required components.
A Smart Motor, Motor Shaft, IQ Brain, IQ Battery, Smart Cable, and a Wheel placed together on a table.
Gather the following items:
  • 1 VEX IQ Smart Motor
  • Any metal Motor Shaft
  • VEX IQ Robot Brain
  • VEX IQ Robot Battery with Robot Battery Fault (blinking red Charger LED)
  • 1 Smart Cable
  • 1 Wheel or gear
Step 2: Insert the Robot Battery into the Brain.
Diagram shows a Battery being connected to an IQ Brain. An arrow indicates that the Battery should be pushed into the charging port on the bottom of the Brain. The Battery is oriented with its latch facing away from the Brain.
NOTE: Slide the Robot Battery into the Brain until you hear the latch click.
Step 3: Attach the Smart Motor.
Diagram  of an IQ Brain with a Smart Motor connected to one of its Smart Ports.
Connect the Smart Motor to any Smart Port using a Smart Cable.
Pull gently on both ends of the Smart Cable to ensure that it is attached securely.
NOTE: Make sure that both ends of the Smart Cable are inserted fully. A click sound should be made when they are connected.
NOTE: Make sure that the Smart Motor is the only device connected to the Brain.
Step 4: Attach the wheel.
An IQ Brain with a Battery is placed on a table. A Smart Motor is connected to one of its Smart Ports. A Motor Shaft attached to a Wheel piece is connected to the Smart Motor, so that when the Wheel spins the Smart Motor will spin as well.
Insert the Motor Shaft into the Smart Motor.
Attach the wheel to the Motor Shaft.
NOTE: Ensure that the Motor Shaft is inserted properly so that the wheel does not slide down the shaft.
Step 5: Rotate the wheel.
An IQ Brain with a Battery is placed on a table. A Smart Motor is connected to one of its Smart Ports. A Motor Shaft attached to a Wheel piece is connected to the Smart Motor. Arrows indicate that the Wheel piece should be rotated quickly.
Rotate the gear/wheel back and forth quickly for about one minute.
Remove the Robot Battery from the Brain after approximately one minute and quickly place the Robot Battery on the Battery Charger.
NOTE: When rotating the gear/wheel, the Brain LED light will flash and/or the Brain’s LCD screen will flash. The Brain may turn on.
NOTE: If the manual charge was successful, the LED light on the Battery Charger will be solid red after the Robot Battery is slid into the cradle.
If the above procedure does not work, contact VEX support at support@vex.com.
For further instructions, click one of these links:
