Mounting and Wiring the V5 Battery
Collect all needed parts
Pieces needed to mount the V5 Battery are placed together. The pieces shown include 2 V5 Battery Clips, 4 #8/32 Screws, 4 #8/32 Keps Nuts, and 1 Hex Key.
You will need:
  • (1) V5 Robot Battery (not shown)
  • (1) V5 Robot Battery Cable (not shown)
  • (2) V5 Battery Clips
  • (4) #8-32 x 1/2" Screws
  • (4) #8-32 Keps Nuts
  • (1) 3-32" Hex Key
When you want to wire the battery, you will also need the V5 Robot Brain mounted to your robot. >
Mount the V5 Battery Clips
Two V5 Battery Clips have been attached to the back part of the robot and they are highlighted.
Mount the two V5 Battery Clips underneath the back part of the base of your robot.
Secure the V5 Battery into the clips
V5 Battery has been attached to the two V5 Battery Clips on the back part of the robot.
Press the battery into the clips until you hear and feel it click into place.
Connect the V5 Robot Battery
V5 Battery Cable is shown connecting the V5 Battery to the V5 Brain on the robot.
Wire the battery to the V5 Robot Brain using the battery cable.
Be sure to insert the battery cable's connectors correctly so they click into place.
For more detailed instructions on mounting and wiring the battery, see the V5 Clawbot Build Instructions.
