Mount and Wire - Battery for VEX V5
Step 1: Collect all needed parts
  • You will need:
    • (1) V5 Robot Battery (not shown)
    • (1) V5 Robot Battery Cable (not shown)
    • (2) V5 Battery Clips
    • (4) #8-32 x 1/2" Screws
    • (4) #8-32 Keps Nuts
    • (1) 3-32" Hex Key
  • When you want to wire the battery, you will also need the V5 Robot Brain mounted to your robot.
Step 2: Mount the V5 Battery Clips
  • Mount the two V5 Battery Clips underneath the back part of the base of your robot.
Step 3: Secure the V5 Battery into the clips
  • Press the battery into the clips until you hear and feel it click into place.
Step 4: Connect the V5 Robot Battery
  • Wire the battery to the V5 Robot Brain using the battery cable.
  • Be sure to insert the battery cable's connectors correctly so they click into place.
  • For more detailed instructions on mounting and wiring the battery, see the V5 Clawbot Build Instructions.
