Using the Smart Ports on the V5 Brain
Connect a V5 Smart Cable to the device
V5 Smart Motor with a Smart Cable plugged into its cable port.
Push the end of a V5 Smart Cable into the device's cable port until you hear it click into place.
In the image above, a V5 Smart Motor is being used.
Connect the V5 Smart Cable to the V5 Robot Brain
V5 Smart Motor with its Smart Cable plugged into the V5 Brain's 10th Smart Port.
Push the other end of the cable into a port on the V5 Robot Brain until you hear it click into place.
In this picture, Port 10 was chosen for the connection. You can choose any open port.
Check the Device Info screen to see the new device
Brain screen is shown in the Device Info menu which has a list of all of the Brain's Smart Ports and connected devices. In this example, there is a connected Robot Battery and there is a Smart Motor connected in Port 10.
Press the Devices icon on the Home screen of the V5 Robot Brain to see that the device is recognized on the port you connected to.
