Using the Default Sensors Program on the VEX IQ (1st gen) Brain
The Sensors Program is a default program built into the VEX IQ Robot Brain so it can be used with Sensors and the VEX IQ Controller without programming. The Driver Control program contains sample behaviors for all advanced sensors. The Sensors Program works much like the Driver Control Program but in this program, the Controller’s commands are also influenced by the sensor readings.
Sensor   Behavior
Touch LED Diagram indicating that the Touch LED can be pressed to change between enabled and disabled modes. When it is enabled, the Controller will function and when it is disabled the Controller will not function. Tap the top dome of the Touch LED to change between
enabled (glowing green) and disabled (glowing red) modes.
Color Sensor Diagram indicating that the Color Sensor can detect green and red colors to change between enabled and disabled modes. When it is enabled, the Controller will function and when it is disabled the Controller will not function. When the Color Sensor sees a red or green object, it will
be disabled or enabled, respectively.
Gyro Sensor Diagram indicating that when the robot is not being controlled it will automatically turn back to its original heading using its Gyro Sensor. When you stop driving, the robot will automatically turn back
to its original direction (i.e., heading).
Distance Sensor Diagram indicating that when the Distance Sensor detects a nearby object it will stop the robot from driving any closer to that object. When the Distance Sensor detects an object that is too
close to the robot, it will stop the robot from colliding with that object.
Above is a view of the Brain's Smart Ports, with 6 on opposite sides for 12 total. Below is a view of the Brain's screen and buttons.
Smart Port Number Sensor Type
1 No sensor
2 Touch LED
3 Color Sensor
4 No Sensor
5 Gyro Sensor
6 No Sensor
7 Distance Sensor
8 No Sensor
9 Touch LED
10 No Sensor
11 No Sensor
12 No Sensor
NOTE: First, the Sensors program will check for Smart Motors and Bumper Switches configured in the Smart Ports listed for the Driver Control program. If the program does not find Smart Motors or Bumper Switches, it will check for the devices listed in the table.
  • Check that Smart Ports 1-12 have the correct types of devices listed in the table above.
  • Check that the Controller is wirelessly connected.
NOTE: To review how to connect devices to Smart Ports properly, click here. To review how to pair the VEX IQ Controller and Brain, click here.
On the left the Brain's screen is shown in the Programs menu and the Demos option is selected. On the right the Brain's screen is shown in the Demos menu and the Sensors option is selected.
The Brain's screen is shown while the Sensors program is running. The program has been running for 1 minute and 8 seconds and the screen reads Running.
After powering on the Brain, highlight and press the Check button to select Demos.
Highlight and press the Check button to start the Sensors program.
Use the Controller to move the robot.
