The following article will walk you through how to install VEXcode AIM with MSI installers.
MSI installers are created to assist IT Administrators with site-wide deployments. If you are not an IT Administrator, read Installing VEXcode AIM on Windows.
Note: Drivers are automatically included with the MSI Installer.
Steps for Installation
- If you are using a remote deployment system such as SCCM you may need to install the Driver Signing Certificates before running the driver installer.
- Download these four certificate files:
- Certs can be installed with the following commands using Microsoft’s certutil command.
certutil -addstore "TrustedPublisher" RobomatterIncCert.cer
certutil -addstore "TrustedPublisher" VEXRoboticsCert20.cer
certutil -addstore "TrustedPublisher" VEXroboticsCert23.cer
certutil -addstore "TrustedPublisher" VEXRoboticsCertExp2026.cer
Go to the VEXcode AIM installation page to download the latest MSI Installer.
- You are now able to use the downloaded MSI Installer to deploy VEXcode AIM systemwide.
