When configuring the AI Vision Sensor on the VEX AIM Coding Robot in Web-based VEXcode AIM, the computer will ask for permission to use your camera. If you do not select Allow, the sensor will not be able to connect to VEXcode. To fix this issue, follow the steps below:
1. Select the settings icon to the left of the page’s URL.
2. Select Reset Permissions.
3. You will be prompted to reload the page. Select Reload.
macOS
Windows/Chromebook
Select each image above to enlarge.
4. Return to the AI Vision Utility. You will now be able to connect the sensor again and select Allow while visiting the site.
