Adding a Note to a Project
Add a note to the Workspace by right-clicking to open the context menu. Then select Add Note.
Change the size of the note by selecting the lower right corner of the note and dragging to the desired size.
Select anywhere else on the note and drag to move it around the Workspace.
Then, type any text, numbers, or symbols into the note.
- Use the Return or Enter key on your keyboard to write a multi-line note.
- Select anywhere in the Workspace when the note is complete.
Deleting Notes
Delete a note by selecting the X located at the top right of the note.
Notes can also be deleted by opening the context menu and selecting Remove Note.
