Calibrating the One Stick Controller is a useful troubleshooting tool if your VEX AIM Coding Robot is not moving as expected when using the Drive program. This article will show you the steps to calibrate the One Stick Controller.
Begin with the One Stick Controller off. If the controller is linked to an robot, turn off the robot as well.
Press and hold the Right, Down, and Power buttons for approximately two seconds, until the indicator light in the power buttons glows purple.
Rotate the joystick in a complete circle, until the indicator light glows blue. Wait until the indicator light begins to flash blue.
While the indicator light is flashing blue, press the Left button. The indicator light will glow green, indicating that the calibration process is complete.
