Renaming the VEX AIM Coding Robot
The VEX AIM Coding Robot can be renamed, making it easier to identify which robot is which.
Naming the Robot
Robot icon on the top right of VEXcode AIM.
When the robot is connected, select the Robot icon.
Edit robot's name on the top right side of the VEXcode AIM screen.
Select the Edit option next to the robot's current name.
Robot name is updated to MyRobot. The update button is highlighted in red box.
Update the name, then select Update.
Note: Spaces are not accepted. Use underscores to separate words. The maximum length is 7 characters.
Robot name is updated in the robot screen. The robot name is highlighted in red box.
You will now see the updated robot name when the Robot icon is selected.
Viewing the Name of the robot
The Robot icon on the robot screen is selected in red box.
The current name of the robot can also be viewed by selecting the option at the bottom of the robot's main screen.
Robot name and battery level shown on the screen.
The robot's current name and battery level will be shown.
