After downloading a project to the robot, you can run, stop, and delete the project directly from the VEX AIM Coding Robot's screen.
Running a Project
Navigate to Projects, and tap to select it.
Navigate to the project you wish to run.
Tap the Run button to run the project.
Stopping a Project
While a project is running, you can swipe the robot's screen at any time, and the Stop button will appear. Tap the Stop button to stop the project.
You can also stop a project while it is running by pressing the power button on the rear of the robot at any time.
Deleting a Project
Within the Projects menu, navigate to the project you wish to delete, and tap to select it.
Navigate to the Delete option, and tap to select it.
Tap the Confirm Delete button to delete the project from the robot. Once deleted, the project will no longer appear in the Projects menu.
