This article outlines how to charge and power the One Stick Controller, so you can get started using the controller with your VEX AIM Coding Robot.
Charging the One Stick Controller
The front of the One Stick Controller has a USB-C port used for charging.
Use a USB-C cable to connect the One Stick Controller to a computer or power source. When connected, the indicator light in the power button will glow to indicate that the controller is charging.
The battery level of a linked controller can be viewed in the robot's Dashboard. View this article to learn more about using the Dashboard.
Powering the One Stick Controller
Turn on the One Stick Controller by pressing the power button on the top of the controller, as shown in this animation. The indicator light in the power button will glow to indicate that the controller is powered on.
To turn off the One Stick Controller, press and hold the power button until the indicator light turns off.
Once charged and powered on, the One Stick Controller can be connected to the robot. View this article to learn how to link the One Stick Controller and robot.
