To print to the Console in web-based VEXcode IQ, a connection to the Console Serial Port is needed. This second port is needed because the first serial port links the IQ (2nd gen) Brain to the device for project downloads from a browser.
Note: To print to the Console, the IQ (2nd gen) Brain must stay connected to the device via a USB cable while using the Console Serial Port.
If the Console Serial Port is not connected, the Print Console in VEXcode IQ will show as unavailable.
Connecting to the Console Serial Port
Ensure the IQ Battery is charged and is connected to the IQ (2nd gen) Brain.
Turn on the Brain by pressing the Check button on the Brain.
Connect the IQ (2nd gen) Brain to your device using the USB-C cable.
Ensure the IQ (2nd gen) Brain is connected to the device via the first web-serial port. For more information on this connection process, view the article for your device:
Once the Brain is connected to the first web-serial port, select the green Brain icon.
Select Connect Console Serial Port.
macOS/Chromebook
Windows
Select each image above to enlarge.
A prompt will appear based on your device. Select Continue.
macOS/Chromebook
Windows
- macOS/Chromebook: Select the IQ (2nd gen) Brain with the HIGHEST ID number from the list of Brains available. The lowest ID number will already be paired.
- Windows: Select User Port. The Communications Port will already be paired.
macOS/Chromebook
Windows
Select Connect once your choice is highlighted.
Once the connection is successful, the Console Serial Port will display as Connected. The Print Console will now be available for use.
Disconnecting from the Console Serial Port
To disconnect your device from a IQ (2nd gen) Brain, unplug the USB-C cable from your device or the Brain.
You can also disconnect a IQ (2nd gen) Brain from web-based VEXcode IQ by turning the Brain off.
Turn the Brain off by holding the X button until the screen on the Brain goes black.
Both of the methods above will disconnect the IQ (2nd gen) Brain from both web-serial ports, showing the Brain icon as white.
