Understanding the V5 Radio LED Lights
You can monitor the LED lights on your V5 Radio to check your robot's status.
Mounted and wired V5 Robot Radio is shown on a V5 robot. In this example, the Radio's LED lights are solid red.
A solid red LED indicates:
  • That there is no radio connection between the V5 Brain and V5 Controller.
Mounted and wired V5 Robot Radio is shown on a V5 robot. In this example, the Radio's LED lights are flashing red.
A flashing red LED indicates:
  • An active connection between the V5 Brain and V5 Controller.
  • The V5 Controller is not plugged into a field control system or the V5 Brain is not running a user program.
Mounted and wired V5 Robot Radio is shown on a V5 robot. In this example, the Radio's LED lights are flashing green.
A flashing green LED indicates:
  • The V5 Controller is plugged into a field control system.
  • The V5 Brain is running a user program.
