Code Base 2.0: Features and Improvements
The VEX GO Code Base 2.0 represents a significant evolution from the original Code Base, offering both structural and functional upgrades that enhance performance and ease of use. Here’s a closer look at the differences and improvements that make Code Base 2.0 stand out.
Angled side view of the new Code Base 2.0 robot.
These same design updates were applied to all GO robot builds that previously used a 4-wheeled design including the Code Base series and the Competition Hero Robots.
Check out the updates in all of the build instructions at builds.vex.com or by following the link to the Code Base 2.0 build instructions here:
Design Update
One of the most noticeable changes in Code Base 2.0 is its 3-wheeled design.
Top down view of the Code base 2.0 robot.
This configuration replaces the original 4-wheeled design of the Code Base, resulting in several key benefits:
  • Faster Build Time: The simplified 3-wheeled structure reduces assembly complexity, allowing students to complete the build more quickly.
  • Better Straight-Line Driving: With fewer wheels, the Code Base 2.0 drives more reliably in a straight line, enhancing its consistency during programmed navigation tasks. A 4-wheeled design often requires perfect alignment of all wheels to drive straight, which can be difficult to maintain over time.
  • Improved Maneuverability: This 3-wheeled design includes two powered wheels and one free-spinning caster wheel. This arrangement allows for smooth and precise turning.
Code Base 2.0 driving on a GO Field. The battery's charging port is located on the back of the robot in an easy to reach spot and is called out in a red box.
In addition, the design has been changed to allow for easier access to the charging port of the VEX GO Battery. This allows teachers and students alike to easily charge their Batteries between sessions without needing to disassemble the robot.
Firmware Enhancements
To complement its hardware upgrades, firmware updates were introduced to further improve the robot’s driving and turning precision. These updates ensure:
  • More reliable movement values, making coding tasks more predictable.
  • Better turn accuracy, which enhances performance in activities requiring precise navigation.
Why These Changes Matter
The updates in Code Base 2.0 make it more student-friendly, especially for beginners in robotics. The quicker build time and improved driving reliability allow students to focus more on coding and problem-solving rather than troubleshooting mechanical issues.
By embracing the advantages of a 3-wheeled design and upgrading its firmware, the Code Base 2.0 offers a smoother, more reliable, and efficient experience for learners exploring robotics and coding concepts.
