Connecting an IQ (2nd gen) Controller to Virtual Driving Skills
VEX IQ Robotics Competition (VIQRC) Virtual Driving Skills Practice allows you to connect a VEX IQ (2nd gen) Controller to your computer and complete practice Driving Skills matches. This article walks through how to connect your Controller to VIQRC Virtual Driving Skills.
Note: An IQ (2nd gen) Controller is required when using VIQRC Virtual Driving Skills.
Connect to an IQ (2nd gen) Controller
VEX IQ (2nd gen) Controller with its Power Button highlighted and its Power LED light glowing green and highlighted.
Turn on your VEX IQ (2nd gen) Controller using the power button.
Top down view of a laptop and controller connected via a USB C Cable.
Connect the Controller to your computer using a USB-C cable.
Controller status section of the Driver Skills page. On the left is the current status of the controller which reads Not Connected in this example. On the right is the button to connect the controller which is highlighted with a red box.
Select Connect Controller on the Virtual Driving Skills page.
Mac / Chromebook
VEXcode IQ Browser Controller Connection prompt with a message that reads Your browser will now attempt to connect to your IQ Controller. On the browser connection prompt, please select the item labeled VEX Robotics IQ Controller with the lowest ID number and press Connect on the connection prompt. There are two buttons below, one reads Cancel and the other reads Continue.
Windows
VEXcode IQ Browser Controller Connection prompt with a message that reads Your browser will now attempt to connect to your IQ Controller. On the browser connection prompt, please select the item labeled VEX Robotics Communications Port and press Connect on the connection prompt. There are two buttons below, one reads Cancel and the other reads Continue.
A device-specific prompt will appear to explain what to select in your browser's connection window.
  • Mac and Chromebook users will be instructed to select the option with the lowest ID number.
  • Windows users will be instructed to select the option labeled "Communications Port".
Select Continue to open your browser’s connection window.
Connect button in the browser connection window shown in bright blue indicating that a controller has been selected. A red box is highlighting the button.
Select the option with the lowest ID number or the option labeled "Communications Port", then Select Connect.
Controller Status section of the Driver Skills page. On the left is the current status which reads Connected and has a green background.
Your VEX IQ (2nd gen) Controller will now be connected to VIQRC Virtual Driving Skills. The Controller Status will turn green and say Connected.
