Many VEX EXP products contain their own internal processors and run on a special Operating System known as "VEXos". This Operating System is written entirely by VEX Robotics, and harnesses the flexibility and power of VEX hardware for the diverse needs of education and the rigors of competition.
VEXos allows for advanced programming features and an enhanced user experience. The best way to ensure that your EXP system is functioning properly is to keep the firmware up to date. This is done simply by opening VEXcode, then plugging your EXP Robot Brain into your computer and following the prompts. The Brain will then automatically push out the latest updates to any V5 device that is connected to it.
VEX EXP Brain Firmware
VEXos Version 1.0.7
Released September 2024
- Bug Fixes and updates for VEX CTE devices
VEXos Version 1.0.4
Released March 2024
- Added support for new AI Vision Sensor
- Added ability to check VEXos Version by holding the Check button for 2 seconds.
- Other minor bug fixes.
VEXos Version 1.0.3
Released February 2023
- Fixed issue with optical sensor's brightness value on dashboard screen
- Updated internal drive program to offer split arcade on alternate joystick axis.
VEXos Version 1.0.2
Released September 2022
- Improved Vision Sensor communication
- Improved controller pairing animation graphic on brain screen
- Fixed issue with system crashing when SD format not supported
- Improved robustness of radio communications during program downloads via controller.
- Improved IMU error handling
- Fixed issue with Controller firmware hanging during use.
